EDIT with additional information that I forgot to mention in my original post.
Neither method works after using ‘camera.TakePicture()’. Take picture or streaming give exceptions.
Yes! it could be my code but I ‘think’ (could very well be wrong) that the spider I/O cannot communicate with the camera?
I worked around this just using streaming to capture a single picture bitmap to save to file but I ‘think’ I should be able to use either OR both methods.
Sure would like to know why. I’ll leave it at that.
Ya’ all have a GREAT day!
As a note my camera shows version 1.1. My question relates to coding for it.
I have no issues getting images from it.
I have two uses for the camera in my code.
- Buttons to start/stop/save image for streaming.
- Buttons for Takepicture/save fo snapshot.
Each (1 and 2) works on its own without any problems. I can receive images and can display/save the bitmaps to file.
My problem is whenever I use camera.TakePicture(); I then can no longer stream the camera.
Exception received is:
Exception System.Exception - 0xffffffff (1)
#### Message:
#### GHIElectronics.NETMF.USBHost.USBH_Webcam::StartStreaming_Internal [IP: 0000] ####
#### GHIElectronics.NETMF.USBHost.USBH_Webcam::StartStreaming [IP: 0005] ####
#### Gadgeteer.Modules.GHIElectronics.Camera::StartStreamingBitmaps [IP: 007e] ####
#### GadgeteerSpiderServer.Program::StreamOn [IP: 0057] ####
#### GadgeteerSpiderServer.Program::processSpecial [IP: 010e] ####
#### GadgeteerSpiderServer.Program::TestBuffer [IP: 010a] ####
#### GadgeteerSpiderServer.Program::XBeeSerial_LineReceived [IP: 002c] ####
#### Gadgeteer.Interfaces.Serial::OnLineReceivedEvent [IP: 0037] ####
#### System.Reflection.MethodBase::Invoke [IP: 0000] ####
#### Gadgeteer.Program::DoOperation [IP: 001a] ####
#### Microsoft.SPOT.Dispatcher::PushFrameImpl [IP: 004a] ####
#### Microsoft.SPOT.Dispatcher::PushFrame [IP: 001d] ####
#### Microsoft.SPOT.Dispatcher::Run [IP: 0006] ####
#### Gadgeteer.Program::Run [IP: 001c] ####
#### GadgeteerSpiderServer.Program::Main [IP: 001a] ####
A first chance exception of type ‘System.Exception’ occurred in GHIElectronics.NETMF.USBHost.dll
Error invoking method “Gadgeteer.Interfaces.Serial” (check arguments to Program.BeginInvoke are correct)
This Information, in my mind, tells me nothing! I assume it is related to the USBHost?
The streaming method returns and I never receive the GTM.GHIElectronics.Camera.BitmapStreamedEventHandler(camera_BitmapStreamed); event.
//Partial code
//Camera events
cameraSocket4.PictureCaptured +=
new Camera.PictureCapturedEventHandler(camera_PictureCaptured);
cameraSocket4.BitmapStreamed +=
new GTM.GHIElectronics.Camera.BitmapStreamedEventHandler(camera_BitmapStreamed);
Bitmap PicBitmap;
byte[] cambytes;
Image imgCamera;
//The picture returned in PictureCaptured is a valid .BMP file.
void camera_PictureCaptured(Camera sender, GT.Picture picture)
//Save GT.Picture picture for saving this picture data to SDCard
pictureSnapped = picture;
//Display the picture on canvasData
imgCamera = new Image();
imgCamera.Bitmap = picture.MakeBitmap();
canvasData.Children.Clear();
canvasData.Children.Add(imgCamera);
Canvas.SetLeft(imgCamera, 0);
Canvas.SetTop(imgCamera, 0);
lcdData.Visibility = Visibility.Visible;
lcdWiFly.Visibility = Visibility.Hidden;
private void camera_BitmapStreamed(Camera sender, Bitmap bitmap)
PicBitmap = bitmap;
imgCamera.Bitmap = bitmap;
private void StreamOn()
//Create new event -- [b]Added to the original code to see if a new event would help[/b]
cameraSocket4.RestartStreamingTrigger = 1500;
//Start streaming and tell PC
XBeeSerial.Write(XB + "Camera streaming on~");
Thread.Sleep(500);
cameraSocket4.StartStreamingBitmaps(new
Bitmap(cameraSocket4.CurrentPictureResolution.Width,
cameraSocket4.CurrentPictureResolution.Height));
private void StreamOff()
//Stop streaming and tell PC
XBeeSerial.Write(XB + "Camera streaming off~");
cameraSocket4.StopStreamingBitmaps();
private void TakeSnapShot()
cameraSocket4.TakePicture();
Is there any way to ‘reset’ the camera after using the cameraSocket4.TakePicture(); method?
Any ideas?
Thanks!
