A question about using PWM on BrainPad
I ask because I do not understand why I get the following exception when creating a new PWM. I am not saying anything about right or wrong here.
Example using Expansion Port E13:
If I use (For the first time).
static PWM pwmExpansion;
pwmExpansion = new PWM(BrainPad.Expansion.PwmOutput.E13, 50, 0.05, false);
I receive the exception:
A first chance exception of type ‘System.InvalidOperationException’ occurred in Microsoft.SPOT.Hardware.dll
So in order to create the PWM I must do another:
This time I do not receive the exception and I have a useable PWM.
Is there something I need to do to prevent the exception on the first instance? Receiving the exception do not seem to cause any problem but it seems kind of crude coding. But it does work then.
Some sample code I used to show the issue.
There is not much code if you remove all the BrainPad.WriteDebugMessages.
namespace MFConsoleBrainPadQuestion
        static bool Expansionstarted = false;
        static bool isfirst = true;
            Debug.Print(Resources.GetString(Resources.StringResources.String1));
            BrainPad.Display.Clear();
            //InterruptPort is set as: Port.InterruptMode.InterruptEdgeBoth for all four buttons
            //I only want to respond when the button is released
            BrainPad.Button.ButtonReleased += Button_ButtonReleased;
            BrainPad.WriteDebugMessage("BrainPad Is Running.  Using PWM on Expansion E13");
            BrainPad.WriteDebugMessage("Expansion pin E13 is high (1) at power on/reset\r\nPress the Left button to begin.");
            while (BrainPad.Looping)
                Button();
                BrainPad.Wait.Milliseconds(200);
        static bool Leftbuttonreleased = false;
        static void Button_ButtonReleased(BrainPad.Button.DPad button, BrainPad.Button.State state)
            if (button == BrainPad.Button.DPad.Left)
                Leftbuttonreleased = true;
        static void Button()
            if (Leftbuttonreleased) //Left button was pressed and then released so continue on
                BrainPad.WriteDebugMessage("\r\nMsg: Left button pressed and released.");
                if (Expansionstarted)
                    pwmExpansion.Stop();
                    pwmExpansion.Dispose();
                    BrainPad.WriteDebugMessage("Msg: if (Expansionstarted), pwmExpansion Dispose. NO PULSE.  Press button again.");
                    return;
                if (!isfirst)
                    pwmExpansion.Start();
                    BrainPad.WriteDebugMessage("Msg: if (!isfirst), new PWM() - We now have a pulse.  Press button again.");
                    Expansionstarted = true;
                    return;
                // I receive A first chance exception of type 'System.InvalidOperationException' occurred in Microsoft.SPOT.Hardware.dll
                // The try/catch does not respond to this exception
                try
                    if (isfirst)
                        // If I use two pwmExpansion = new PWM(BrainPad.Expansion.PwmOutput.E13, 50, 0.05, false);
                        // the pulse will start on the first button press
                        // 1ms pulse - 50Hz - 05.0%
                        BrainPad.WriteDebugMessage("Msg: if (isfirst)");
                        BrainPad.WriteDebugMessage("Msg: pwmExpansion = new PWM(BrainPad.Expansion.PwmOutput.E13, 50, 0.05, false);");
                        BrainPad.WriteDebugMessage("Msg: new PWM() 1 - Exception when using new PWM()");
                        // pwmExpansion.Start(); //If used E13 pin would go low but have no pulse
                        pwmExpansion.Start(); // E13 pin now has a pulse
                        isfirst = false;
                        BrainPad.WriteDebugMessage("Msg:- new PWM() 2 - No Exception when using new PWM() - We now have a pulse.");
                        return;
                catch (Exception e) // Never comes here
                    BrainPad.WriteDebugMessage("Msg: catch (Exception e)");
                    BrainPad.WriteDebugMessage(e.Message);
                //end try/catch
            } //end if Leftbuttonreleased
        } //end Button()
    } //end program
} //end namespace
Example output:
Hello World!
Msg: if (isfirst)
Just a question I had to ask.
Thanks…
@ willgeorge - If you create a new empty project and just add the PWM constructor, do you still get the exception? Use GHI.Pins.G30.PwmOutput.PB6 instead of including the BrainPad class.
@ willgeorge - Thinking about this more, E13 is one of the I2C pins used by the accelerometer, so it cannot be used for PWM when the BrainPad class is in use and should not be used for anything but I2C even without the BrainPad class. The class will be updated to reflect that.
@ John -
Thanks for the insight.
