We are excited to announce the release of a new SDK! This SDK covers many bugs and adds a few new features. A full list of changes can be found at GHI Electronics – Where Hardware Meets Software . For more detailed changes, please see the release notes included with the SDK.
This SDK is still under testing. If all went well, will post it right on the support page in few days.
We are not seeing the problem (never did) so it is either solved or we are not seeing it. Many things changed so please let us know if you see any issues.
@ RobvanSchelven and @ andre.m - As explained in last reply, the fix is not a problem once we see the problem. So far we have not gotten any straight answer on “use router model 1234 and you will see the problem” We are willing to get as many routers as needed. By the way, we already got few more and tested but still every single one works perfectly.
On my home system, with the prior SDK, I was able to reliably get a DHCP address, but was having a problem instantiating a Socket. Again, this could not be repeated in Michigan.
I think we need to send some of our Cobras back to Michigan to see if they work at their birthplace.
Update… Issue solved … This was a result of doing a Dns.GetHostEntry in a 2nd thread… Since Dns(…) is a static class it conflicted with almost 2 calls at the same time…
