Hello GHI Team,
I wanted to share some feedback after spending more time with the Endpoint Domino.
To put it simply: what you’ve built is genuinely impressive — and far more elegant than most people realize.
Your camera stack in particular stands out.
Compared to the Raspberry Pi ecosystem, where camera integration is a prehistoric mix of V4L2, libcamera, MMAL, GStreamer, ffmpeg, and half‑documented drivers, the Endpoint approach feels almost unreal in its simplicity and consistency.
On the Domino:
USB cameras: plug‑and‑play,
FrameReceivedevents, JPEG frames, snapshot support -
Camera modules: same API, same pipeline, same behavior
Networking: Ethernet, USB‑Ethernet, WiFi — all through a single enum
Debugging: stable, deterministic, with Console output streamed directly in the Config Tool
Runtime: predictable, clean, without the usual Linux noise
Tooling: Endpoint Config is genuinely a highlight
This is a vertically integrated embedded platform — the kind you normally only see from companies like Apple, just tailored for .NET developers.
It’s a rare combination of simplicity, determinism, and thoughtful engineering.
I sincerely hope you continue developing this ecosystem.
And if that’s not in the cards, it would be fantastic to see parts of the hardware design, firmware, or software opened up on GitHub.
It would be a shame for such a clean and well‑designed system to fade away when it clearly has the potential to outlive its initial scope.
Best regards,
Robert
