Hi all guys, I am new here in this forum, I am the one who has been working in Microsoft in the PowerKit Nicolas told you, from now on I will take care of questions and any information you want
Fisrt of all thanks for the interest, very good feedback and such an interesting topics you bring here
@ GMod Yes it looks a bit scary
I have been working on designing this for 2 months and after few prototypes this is what is much easy to use (connect, cables, boards…) maybe there are better ways so I am open to any feedback about the design. The module uses a power monitor from TI INA226. The reason is that it works on its own, so you can just configure it and let it averaging or giving you alerts if something happens, it has a calibraiton parameter so you can change resolution depending on what you connect. This is very important because if you connect a power module the Current could be Amps, while if you connect an LED we are talking about mA, so if you want high resolutions independently of waht you connect it is very useful power monitor. It uses a 0.01 Ohm shunt resistor.
@ mhectorgato I have been testing the module using a T35 display and a cellular radio module, and it is very useful as you can see how each module demands current, how the power supply “suffers” and all this, and as it is an independent system, you can see how Gadgeteer resets and so on, I will send some pictures with the nice graphs exposing all this
@ Jeff_Birt We have designed a single module (see Nicolas pictures) that you can connect to any socket/device/power module, it make its easier and very inexpensive, but the point about having a “Shield” is that sometimes you want to know in detail what is going on in each module/socket, record all data and look at it afterwards, re-play a power sequence to find very small spikes or flickering of the voltage that made to board to reset… if you use a multimeter you just get very big averages of current, where you can’t actually see spikes (as the GPRS module does) that make the main board to reset.
One point I find very interesting, and I think will be what will make this to be nice, it the possibility to add power managment code! I mean, you can connect the power module to your main board and make real time power managment within your code, or even, if you can have the power board running on the side communicating with your main board using serial for example. It could improve a lot designs and make all power managment less painful (specially for non hardware people, as we are aiming to them mainly).
If you have any feedback/comments or just dont agree about something let me know and I will answer! thanks for reading!!
Jordi
