I have a 7" display on stock and I tried to connect it to the EXM. Unfortunately, the display has for each of the color channel 6 bits, the EMX supports only 5 bits for the red and blue channel. The green has 6 bits.
The display works, but the colors are not acceptable, because the EXM supports RGB 565 and the display can works with RGB666.
In any case, always connect the unused LSB to ground, not the MSB,so that it will have minor impact on color restitution, but I guess it was clear for anyone…
