I had to get a board made quickly so instead of sending it to the usual suspects in China i am getting it made locally (Ireland) by PCB Pool with a 1 day turn around.
Board is a fairly vanilla 2 layer design.
Using PCB Pool they send you a pickie of your board at each manufacture step which is quite fascinating to watch (ok maybe i need to get out more… )
Drills
UV expose top
UV expose bottom
Strip top
Strip bottom
UV cure top
UV cure bottom
Surface finish
Mill the outline
